A different starting problem
Old Mar 26, 2006 | 09:41 PM
bixing's Avatar
Default A different starting problem
Hi
I was having problem with my 1996-E320 starting...but then I thought I rectified it .... LOL....I know now...as the car started giving problem again today.
when i try to start... even the dashboard lights dont come up...but after a few tries..it lights up..and it starts..
at times..when the lights dont come up, the key doesnt go to the starting point..feels like as if its stuck..i have to take the key out..and after quite a few tries..it starts....I just dont get it,..please help...
Thanx
Old Mar 27, 2006 | 06:34 PM
bixing's Avatar
Default RE: A different starting problem
hey guys..
somebody help.....
Old Mar 27, 2006 | 10:13 PM
sleepwalker's Avatar
clean the battery terminals.
Old Mar 27, 2006 | 10:55 PM
bixing's Avatar
Thanx.. I ll do that... Me too bad in this stuff I think....absolutely newbie
Old Apr 5, 2006 | 07:39 PM
bixing's Avatar
Hi sleepwalker and every other exp. MB guy
So I did clean the battery terminals last week... The terminals were clean though the connecting wires were a bit rusty... so i cleaned
.. and it worked fine for 3-4 days.. but then again ..it started having problems
Again..the backlights wont come up..only the mileage comes up (which also keeps flickering at times).... the car cranks but wont start until the dash lights come up nicely and fully....
Otherwise..the car is fine once it starts.....But there is no problem with interior lights or headlights which shows battery is fine...
Anything that I can check...
Old Apr 5, 2006 | 09:50 PM
Battlecat714's Avatar
Just check the battery life just incase, take it pep boys and have them test it, its free anyways. it also might be faulty electrical wiring.
Old Apr 5, 2006 | 10:50 PM
Laterthatsameday's Avatar
I've put a lot of ignition switches in '96 and '97 210's for this complaint.
Old Apr 6, 2006 | 12:34 AM
it seems like there's no enough cranking amperes to the starter?
the cluster will go dim whenever you crank only or even with just ignition "on".
if you turn on the headlights and crank it, the headlights go dim also?
Old Apr 7, 2006 | 05:18 PM
  #9
bixing's Avatar
No, the headlights dont go dim when I start it or crank it..
But today,, the car turned off on its own while I was driving on the highway... Luckily no one else was around and I was safe...
again restarted and came home...
I think it might be a problem with ignition switch... how do i check it and rectify this...can i buy ignition switch from somewhere and change it on my own??
any suggestions and advice is welcome
thanx
thequif
Nov 10, 2017 12:21 PM
emb145fo
Aug 22, 2007 10:18 AM
anyello76
Mar 18, 2006 10:40 PM
Xlr8tin
Feb 21, 2006 09:04 PM
torhovl
Jan 2, 2006 05:44 AM
