Different Hydraulic Leak
Old Feb 15, 2005 | 06:52 PM
emb145fo's Avatar
Default Different Hydraulic Leak
I have a 1995 SL320. I had a hydraulic leak around the sun visor. I fixed it just fine. Now I am leaking Hydraulic Fluid like crazy. It comes out just in front of the passengers side rear wheel. I will lose over half of the hyraulic fluid in the resevoir with just one use of the soft top. It also appears to be slow leaking when nothing is in use. I have no idea on this one. Can anyone help?
Old Feb 16, 2005 | 12:29 AM
sleepwalker's Avatar
Default RE: Different Hydraulic Leak
with all those hydraulic lines and components you got.... only by visual check tht you can know the source of leak.
[IMG]local://upfiles/1/4DBBE68DF66940D988B24048FD8D596B.jpg[/IMG]
[IMG]local://upfiles/1/FDFA583C0A444D91B1664877F69FDF48.jpg[/IMG]
[IMG]local://upfiles/1/B48B32A3925B43B3BD57B8AE3FE88322.jpg[/IMG]
Old Jun 24, 2007 | 10:09 AM
tapas's Avatar
Can you please tell me how you have fixed hydraulic leak around the sun visor?
thanks
Old Jun 24, 2007 | 10:28 AM
SunGuy62's Avatar
tapas,
Use this link for the DIY article on this simple repair.
http://www.mercedesshop.com/Wikka/R129TopRelease
When you get BOTH front cylinders out (as it is highly recommended to repair both the fronts at the same time) you can send them to:
Mercedes Hydraulic Cylinder Rebuilder
Dennis Ficken
16285 S. Chester
Olathe, Ks 66062
(913) 390-0506
mercedescylinders@sbcglobal.net
Dennis has rebuilt hundreds of these for us owners, 1 day turnaround after receipt, 3 yr. warranty. Cost is around $35@ + shipping. Contact Dennis for details.
Or, you can buy new cylinders online or at the Dealer for around $125@ w/1 yr. warranty.
Bob
Old Jun 25, 2007 | 02:07 AM
lynns's Avatar
ORIGINAL: tapas
thanks
Please read http://www.benzworld.org/forums/r129...ml#post2262978
Old Aug 14, 2007 | 08:37 PM
tap_bui's Avatar
Dear Friends,
I have received the repaired struts from Dennis. I've also put them back in place. But I hesitated to activate the covertible top until I fill up the lost oil. I've order the hydraulic oil and it's on its way to my house. Could you kindly show me how to fill the oil? Where is the reservoir? I have the 1990 Mercedes 500SL. Thank you, all!
Tap
Old Aug 14, 2007 | 10:16 PM
SunGuy62's Avatar
Your reservoir is under the spare tire in the trunk.
Bob
Old Aug 22, 2007 | 10:18 AM
Scott M's Avatar
I just had Dennis rebuild my two visor struts and used stop leakpower steering fluid in the reservoir for the lost fluid. Only cost me $95 total and everything is working fine.
Scott
4smith
Jun 4, 2014 01:20 PM
leaker
Sep 13, 2008 09:39 PM
cicaled
Apr 28, 2007 11:57 PM
jpsetlif
Oct 18, 2006 01:52 AM
