Defective Cluster
Old Dec 2, 2007 | 07:54 AM
Hi Fi's Avatar
Default Defective Cluster
Does anyone know if the temperature display and the gear and clock section can be replaced? All the other parts of my cluster are ok but these parts (5,14,15)don't display well can't see all the info only part of it.
Thanks. http://www.geocities.com/mymercedesb...t_cluster.html
Old Dec 2, 2007 | 10:19 AM
ohlord's Avatar
Banned
Default RE: Defective Cluster
Missing pixels or dead back lighting?
if the back light bulbs are dead you can replace them,if parts of the pixels are missing the cluster needs to be repaired.Go to benzworld.org w210 section diy area at the top of the page also may be more info on the cluster at mercedesshop.com
In the past two weeks or so there was a thread we worked on re: dash lights so search for that thread also on benzworld.org
w210 section,
have fun
ohlord
Old Dec 3, 2007 | 11:45 AM
Hi Fi's Avatar
Missing pixels. Couldn't find the section explaing on how torepair this problem.
If you have a link I would appreciate.
Thanks.
Old Dec 3, 2007 | 12:19 PM
ohlord's Avatar
Banned
search pixels or cluster on benzworld.org w210 section and mbworld.org w210 section.
post by raymond about place to send it out to and they repair missing pixels.
If i run into the post I will send it to you.
ohlord
http://www.bba-reman.com/content.asp..._cluster_range
http://www.bba-reman.com/catalogue/D...ledProduct=391
always confirm year and consult with them about your model and date of production ,located in drivers side door frame.
when you remove it check the connections on the harness just to see if they are loose.
hope this helps
Old Dec 7, 2007 | 06:23 PM
Hi Fi's Avatar
Could this affect the fuel gage not working correctly? When I fill up the gas tank it doesn't go completely up.I didn't do so much KM and it is going down pretty fast. I just bought the car it is my first full tank.Thank-You.
Old Dec 28, 2007 | 10:23 AM
chiro's Avatar
With respect to the fuel gauge ..my 2000 E320 had a similair problem and I had to have the fuel sending unit replaced.
Old Dec 28, 2007 | 12:42 PM
carolinsbg's Avatar
[&o]I have the same problem so I took it to my Mercedes guy and he said it is not worth the cost. But yes it can be done.
jerzstyle00
Apr 22, 2011 10:05 PM
bsomega
Mar 4, 2005 09:20 AM
mbmiller
May 5, 2004 12:02 AM
alanjchan
Dec 18, 2003 04:05 AM
