Cut-out problems with E220
Old Feb 17, 2004 | 08:36 PM
Brian E220's Avatar
Default Cut-out problems with E220
<FONT size=2>I have a strange electrical problem that I hope someone can help me with:</FONT></P>
<FONT size=2>It all started about 2 weeks ago - my 1995 E220 Coupe started cutting out completely - no stuttering, just dead. 2 days later I found the battery dead so took the following actions:</FONT></P>
<FONT size=2>
1. Battery charged and still in decent condition.
2. OVP replaced
It is still cutting out at random times - I drove around for about 10 minutes then it started again
A few more indicators:
1. When it cuts out all of the dashboard warning lights except the SRS light go out. Oil pressure and temperature gauges return to zero.
2. When turning the ignition on and off - if it is still faulty, the dash lights come on then go off (with the exception of the SRS light) and I hear a relay click from the OVP vicinity.
3. If the dash lights stay on (as normal) then the car will start and run for a random time perfectly.
It's almost as if the electrics are hit with a 'spike' and it's latching the OVP relay.
I've been looking for a wiring diagram but no luck yet
Can anyone provide any more clues, source of a wiring diagram or at least tell me what the blessed OVP is connected to?
Thanks.</FONT></P>
Old Feb 23, 2004 | 05:12 PM
II Kings 9:20's Avatar
I had the same problem with my 87 300E.It was the alternator. Testing at the local auto parts store did not show a problem, I took it to an MB mechanic (not the stealership) and they tested the alt. and found it very weak. Replacement cured the problem. Good luck
Graeme
Mercedes A Class
Oct 17, 2009 02:59 PM
V XII
Aug 27, 2008 12:22 PM
fredyflame
Jul 20, 2008 02:58 PM
timsslk
Sep 30, 2005 05:10 PM
c280estateguy
Oct 21, 2003 09:44 AM
