Cooling fan problems
Old Jun 28, 2023 | 02:19 PM
tmelbye's Avatar
Default Cooling fan problems
Hello World,
2011 Mercedes E 220 CDI /D 270.000 km.
Cooling fan runs continuously when car is turned off. Emptying battery.
This starts after turning of ignition, removing key and exiting vehicle. It takes about 20 seconds before there is a relay click and the fan starts.
This happens even when the car is cold.
Fan stops when connector on fan is removed but restarts when connector is put back.
Fan will also stop when ignition is turned on.
Whiles driving the fan operates as normal with speed of fan adjusting to temperature of coolant.
Gauge for coolant temperature functioning as normal.
I have checked all the fuses I can find and there is no visible damage to cables from rodents etc. Can’t see anything abnormal.
My thoughts:
There is power to the fan controller and also can-bus signal. Otherwise the fan would not work normal when the car is running and also stop when the ignition is on.
Temperature sensor should also be working as the gauge is working. If the sensor was malfunctioning the fan should not work as normal when driving, alternating speed depending on temperature.
My suspicion (but not sure if the parts work as I suspect)
Fault in fan controller (located in fan assembly). When not receiving signal from ECU it uses an internal temperature sensor that might be faulty and goes in to a failsafe mode to avoid motor from overheating after driving. (Residual heat keep heating up coolant) (not sure if that is how it works)
or...
Something wrong with the ECU sending the fan in to a failsafe mode to avoid overheating.
I was thinking about broken cable, but then it shouldn’t work when car is on and running.
Any thoughts on what could be failing so the fan goes bananas?
Is there anything I can check to find the broken parts?
A DIY solution suggested to me that I put some thought in to.
Cutting positive cable to fan controller. Putting in a relay that will close the connection when ignition is turned on. (could be any source as the relay doesn’t pull much power).
This will disconnect the power to the fan when ignition is turned off.
Problem with this solution is potential overheating after driving the car and residual heat from engine.
A DIY solution to the overheating problem would be to add a temperature sensor that closes connection when reaching a set temperature. Depending on temperature set on this sensor I should be able to connect this externally to the radiator or any coolant hose. Guess 80 C would be an OK temperature. I would then probably need to add a second relay to avoid power from going backwards to the point where I get power from ignition.
Hang with me (if even possible. I might repeat myself a few places.)
Original positive from cable going to fan controller split in two and connected to pin 30 on both relays.
Original cable going to fan controller connected to pin 87 on both relays.
Ground going to pin 85 on both relays.
Positive from battery (or other constant positive point) to temperature sensor (NO).
Out from temperature sensor to relay 1 pin 86.
Positive from ignition to relay 2 pin 86.
This should (if I’m not totally wrong) separate the two triggering signals so they won’t go backwards. (power from the temperature sensor will not go in to the cable from ignition point and giving me another headache.)
Any thoughts?
Am I way out in my thoughts of a DIY solution (last resort if nothing else works)
Old Jul 1, 2023 | 12:20 PM
tony1963's Avatar
I gotta tell you, without a scan tool, you are flying blind. Using a scan tool you can diagnose the issue. There are no shortcuts.
t0213rw
Dec 22, 2019 06:38 PM
seadog
Feb 16, 2011 07:17 PM
Barry Kerr
Jul 10, 2009 01:10 AM
190eMAN
Jan 5, 2008 12:21 PM
jckawan
Jul 14, 2005 08:22 PM
