Climate Control Display Too Dim...... Plese HELP!
Old Jan 7, 2008 | 03:12 PM
  #11
joeyharp's Avatar
Default RE: Climate Control Display Too Dim...... Plese HELP!
While jiggling the damaged wire there was no more than a two second delay (silimar to the delay that the system has when driving into a tunnel) before the climate illumination would be normal. The second the connection is lost it went back to dim.
Just fixing/replacing the ribbon wire is all you'll have to do, I'm sure. Well, that and billing the glass shop!
JG
Old Jan 7, 2008 | 03:27 PM
  #12
mbe500's Avatar
At this point I would be very happy if its the wire and is simple enough for me to fix. If not, maybe a phone call to the glass shop is next.
Old Jan 7, 2008 | 10:00 PM
  #13
mbe500's Avatar
Well, I inspected the wire and connection and everything looked normal. I did notice the sensor unit was not quite securley fastened so maybe by puttting everything back together that will work. I tested by shining a flashlight at the display, and only direct light would change the brightness. Ill take a test drive in sunlightin the morning. If that doesnt work, I guess ill order a new sensor. I am visting the dealer later this week to get new window trim pieces installed and may have them chaeck the software side of things. Thanks again for your help.
Old Jan 8, 2008 | 01:42 PM
  #14
mbe500's Avatar
Just a quick update. I took the car out for a drive today and the display appears to be working normally. Hopefully the connection was just loose and by securely replacing all the connections that took care of the problem.
Donald C.
Apr 28, 2011 05:01 PM
yas21
Dec 17, 2010 04:04 PM
rskdsk
Oct 22, 2007 05:01 PM
cade111
Jun 16, 2006 05:21 PM
mmbraun
May 26, 2006 02:14 PM
