Check Engine Electronics
Old Jan 10, 2007 | 11:44 PM
ric2k04's Avatar
Default Check Engine Electronics
My car - '96 E320 has this "Check Engine Electronics" and check engine light ON. Any idea or suggestion the cause of it and I read the forum messages which seems like the MAF or Oxygen Sensor is bad. Anyone knowthe location ofOxygen Sensor is at? How difficult is it to replace it yourself? Thanks in advance for the advise.
Old Jan 10, 2007 | 11:53 PM
MBZTech's Avatar
Default RE: Check Engine Electronics
Many things can cause a check engine light to go on. Pull codes on it and let us know. O2 sensors are threaded into the exhaust system. You have one before the catalitic converter and one after. They are easy to change out. Just need a 22mm wrench and need to be able to get under the car.
Old Jan 11, 2007 | 12:00 AM
ric2k04's Avatar
Thanks for your advise MBZTech. I will diagnose to get the code and let you know. Probably on the weekend. [&o]
Old Jan 14, 2007 | 03:29 PM
ric2k04's Avatar
I diagnose the car and it comes-out with error code P1441 "Evaporative Emission Control System Incorrect Purge Flow". Does it means anything major will happen? Although my friend has reset the check engine light to switch-off. Thanks in advance for your advise.
Old Jan 16, 2007 | 02:00 AM
MBZTech's Avatar
There are a few components that go bad in that system.. Nothing that bad will happen. its more of an emissions control....Could be a simple as a bad fuel cap....Or maybe you didnt tighten it down all the way..
Old Jan 27, 2007 | 12:24 PM
refriedbeancounter's Avatar
I have a similar problem with my 96. I tried to accelerate hard from a dead stop and it immediately started to run rough and would not accelerate. The check engine electronics light came on. I shut off the engine and restarted and it works fine now, but the CEL is still on. How do Icheck the codes? How do I reset?
Old Feb 17, 2007 | 02:22 AM
troy6363's Avatar
Hey guys... i just had this problem fixed this weekend. I kept getting the code 0441 incorrect purge flow. turned out to be the purge valve was bad. parts and labor cost were 239 bucks.. talk about a hapy man i am.. i didnt go to the stealership though so im not sure what they would charge...hope this helps.. im new to this forum
[align=left] [/align]
[IMG]local://upfiles/20198/94C9E2926AD740EFB981E09B6EA364CF.jpg[/IMG]
nolen01
May 7, 2015 05:58 PM
ping2day
Feb 11, 2008 09:25 PM
solarant
Dec 27, 2007 11:34 AM
tewlmn97420
Nov 27, 2007 09:43 AM
slee88
Sep 27, 2004 12:16 PM
