Changing oil
Old Sep 19, 2007 | 07:02 PM
Carolina's Avatar
Default Changing oil
I'm new to this game and the changing of an oil filter insert is a brand new concept. The top has an arrow on it (98 E320 wagon}. Which way is indicated loosening and tightening. Also, a precaution of what I need to do and what not to do would be most appreciated. Am changing both oil and filter every 6,000 miles. Good, bad? Any and all advice would be appreciated. Carolina
Old Sep 19, 2007 | 10:40 PM
ohlord's Avatar
Banned
Default RE: Changing oil
Diy on benzworld.org w210 forum you have an fss system so your oil change is every 10k approx..fleece filter mobil 1 0w40 oil synthetic.oil pumped up thru the dip stick tube.pm me if you have questions.diy is very detailed
ohlord
Old Sep 20, 2007 | 06:55 AM
uberwgn's Avatar
ORIGINAL: Carolina
I suspect the arrow indicates the direction of tightening. That plastic cap gets re-torqued to 18 ft*lbs. The threading is conventional: Clockwise to tighten
We use compliant 229.xx oils in our '02 wagon and change when indicated by the FSS system. It's typically around 11k miles. I can't recall, does the 1998MY car have FSS??
Whatever you do, don't use crappy oil in these cars. You will pay for it down the road...regardless how frequently you change it.
luciano136
Jan 6, 2006 06:50 PM
luciano136
Sep 30, 2005 12:08 AM
bbull55
Aug 25, 2005 09:44 AM
rcssafety
Jul 12, 2005 10:58 PM
John 1987
Feb 8, 2004 12:16 AM
