Changing additional turning lights
Does anyone know how to change the bulbs/lights on the turning signal mounted on the side mirrors? I've changed all other turning bulbs from yellow to white except for this one. Please post instructions and places of where to buy or have it done.
RE: Changing additional turning lights
Those are LED's aren't they? Leav'em alone unless you want to replace the whole mirror housing. Just my guess, but they are hell to change, if even possible. If you remove the mirror housing, the lens is tucked into to housing so tight that if you are successful at removing it you run the risk of damaging the paint, cracking the lens, or just flat breaking it. If it's not broke already, don't try to fix it.
talon21psi
02-27-2007 07:17 PM
