Center rear clunk/thud on hard accel in 2004 E320
Old Feb 13, 2019 | 11:29 PM
eileen1272's Avatar
Angry Center rear clunk/thud on hard accel in 2004 E320
Car has 57,000 miles on it. Rear suspension replaced last year w after market standard suspension w conversion kit. Hard acceleration causes a loud clunk/thud that comes from the center rear of the car (literally sounds/feels like the spare tire is lunging--but it's not.) Any ideas of what's causing this problem?
Old Feb 15, 2019 | 02:31 PM
PelicanParts.com's Avatar
Hello and welcome to the forum! Have you put the car on a lift and checked the aftermarket suspension to make sure nothing is loose? What is the conversion kit that you used?
Old Feb 15, 2019 | 02:52 PM
eileen1272's Avatar
HIya! The car has yet to be on a lift--will be next week w the same mechanic who did the suspension. I don't know what suspension kit was used, however, I can find out next week. BTW, the sound comes primarily from rear center/rear right
Old Feb 27, 2019 | 05:31 PM
eileen1272's Avatar
Default Confused now
I've been driving the car like an old lady since the clunking/thud sounds started--so I've not heard the sound since. Yesterday, I brought the car to a mechanic, and told him the problem. He couldn't get it to make that sound while driving (which I found odd). However, when he got it on the lift, he said the rear body to sub frame bushings are bad, and that my left brake line severed while on the lift. I pick up the car today to see if I can get the sound/thud to happen again, and I can't....I now have 2 questions:
1: what gives?
2: is it imperative I have the rear body to sub frame bushings done?
Old Mar 5, 2019 | 02:49 PM
1: what gives?
The bushings are important so you don't have metal on metal contact, which is likely happening if there is an issue with the bushings. I don't know if it will cause a safety issue, the mechanic can assess this.
zeke600
May 29, 2011 04:20 PM
Tgryphon
May 14, 2010 11:41 AM
pjpurfield
Apr 1, 2008 12:54 AM
solvman
Mar 23, 2006 12:20 PM
C230 Sport
Feb 17, 2006 09:08 PM
