cd changer problem
Old Feb 16, 2006 | 02:34 AM
sccchiii's Avatar
Default cd changer problem
The command system on my e430 just started displaying no changer when I hit the cd button and will not play my cd's???? Do I need a new changer?
Old Feb 16, 2006 | 03:14 AM
sleepwalker's Avatar
Default RE: cd changer problem
yes.
try disconnecting-reconnecting the battery to reset it.
Old Feb 17, 2006 | 02:17 PM
raymond~'s Avatar
so as I understand this, it has been working, then suddenly stopped?
can you think of any other symptoms which manifested themselves
right about that time (even if appears coincidental)?
yes, you can disconnect NEG cable from battery but be aware that
you may need to reset, resync some appliances such as outside
mirrors, seating positions, moonroof....
another intermediate method (before NEG lead disconnect) would
be to pull the radio fuse for a few minutes.
or, slide out the head unit and disconnect the power (block connector)
and after making a cup of coffee, return and reconnect. best to connect
the changer to the head unit (plugging in orange fiber harness) to the
changer while the power is off....so that it 'wakes up' to the changer.
the attempt is to disrupt power and cause the head unit to reset. do
you have onboard cell phone? if not, then the fiber circuit should be
direct from head unit, to changer, and back to head unit.
trulegend
Oct 5, 2006 03:28 PM
GARY476
Apr 10, 2006 09:05 PM
Benzaholic
Feb 22, 2006 06:38 PM
arm0rallday
Sep 25, 2005 12:41 AM
