can anybody help please 300e losing spark cant take anymore
1 have a 1990 300e straight six i have replaced just about everthing to do with ignition system been to two garages paid a fortune and still have the same problem and you never know when the car will just lose spark everybody is stumped at my expense ive almost spent as much trying to fix the car as i did buying the car i have posted many treads over the last two weeks at a friends advice and had alot o looks but no help is ther any member of this site that thinks they could help please i need help
I would then start inspecting every wire and connection. I would pull each component from its socket and clean all connections, and disconnect ever wire connection and clean them. While in my hand, I would check as much of the actual wiring as I could. Grounds in particular.And I'd pull every fuse and clean all those connections - the fuses do corrode where they contact their connection.
