A/C kept running-2001 E240
Old 03-24-2006 | 11:09 AM
rmt6668's Avatar
Default RE: A/C kept running-2001 E240
Sleepwalker,
I have tested the 3 pin wires using a Multimeter.
(1) Test the middle pin with AC switch disconnected--->0 Volts & plugging the 3 pin wire to the Blower turn ON full blast
(2) Test the middle pin with AC Switch connected ----->12 Volts & plugging the 3 pin wire to the Blower turn ON full blast
(3) Test the middle pin with AC switch connected (a) Switch 1---> 11 Volts (b) Switch 2--->10 Volts (c) Switch 3--->9 Volts (d) Switch 4--->8 Volts (e) Switch 5--->5.5 Volts
(4) With Engine On, test the middle pin with AC switch connected (a) Switch 1---> 12.5 Volts (b) Switch 2--->12 Volts (c) Switch 3--->11 Volts (d) Switch 4--->10 Volts (e) Switch 5--->7 Volts
Whats odd is that the Blower keep blasting away with or without the AC Switch connected or disconnected.
But the Multimeter detected 12 Volts in the middle pin when the AC Swicth is connected but 0 Volts when discoonected?
  #72
Old 03-24-2006 | 12:45 PM
sleepwalker's Avatar
find a known good blower regulator for testing purpose only to confirm.
that's the easiest way to cure headache.
  #73
Old 03-24-2006 | 10:53 PM
rmt6668's Avatar
Sleepwalker,
Do you know where I can find a new Regulator (reasonable price)? Since your diagnoses is the Regulator?
  #74
Old 03-24-2006 | 11:39 PM
what do you mean by reasonable price?
  #75
Old 03-25-2006 | 01:18 AM
rmt6668's Avatar
What I mean is a website where I can buy discounted, wholesale, 2nd hand or direct from manufacturer, perhaps 10-20% of Recommended Retail Price?
  #76
Old 03-25-2006 | 10:24 AM
you want me to find the website where you can buy the regulator?
i don't even have any idea where you are.
that will be $1.00 charge from you if i will do it.
  #77
Old 03-26-2006 | 06:49 AM
rmt6668's Avatar
Thanks.
I have been fowarded some websites already which I am emailing to now to enquire.
Kind Regards
kdlunn
11-09-2008 05:57 PM
Scott M
06-21-2007 06:00 PM
jhines1978
05-15-2007 10:28 PM
macarose
04-15-2007 03:35 PM
iggottamiya
08-09-2005 04:05 PM
