A/C kept running-2001 E240
Old Mar 12, 2006 | 10:01 AM
rmt6668's Avatar
Default A/C kept running-2001 E240
Can any 1 help me. My A/C kept running non-stop even if I have turn the engine off (key removed). I have unplug power cable to the fan unit beneath the passenger seat dash. Previously the A/C wont even function/response.
Kind Regards,
RMT6668
Old Mar 12, 2006 | 10:20 AM
sleepwalker's Avatar
Default RE: A/C kept running-2001 E240
you mean the blower keep on running?
Old Mar 12, 2006 | 10:29 AM
rmt6668's Avatar
The Air Conditioning kept running eventhough the engine is turn off. Previously the A/C will not work properly, it will run only a couple minutes & then turn off on its own. Also when its running for that couple of minutes, it will not respond to any fan speed adjustment on the dash control but will fluctuate or not respond whatsoever.
RMT6668
Old Mar 12, 2006 | 12:03 PM
let me re-phrase the question.
so how did know you it keep on running?
Old Mar 12, 2006 | 09:23 PM
rmt6668's Avatar
The Blower kept blowing cold (refridgerated) air on its on. With the blower control dial on zero, it kept blowing at mamimum speed.
Even turning off the engine of my 2001 E240 , it kept going. I manage to locate the unit below the passenger seat and unplug the power cable to the Blower.
Can you help me diagnose please?
RMT6668
Old Mar 12, 2006 | 10:56 PM
your a/c control unit got problem.
replace it.
Old Mar 12, 2006 | 11:02 PM
rmt6668's Avatar
Is the AC control unit same as the REGULATOR, which is the small unit attached to the blower assembly. Its a metallic unit which have spiky ends.
RMT6668
Old Mar 12, 2006 | 11:06 PM
the regulator is different. it's on the blower down there.
the control unit is the pushbutton on the center console.
Old Mar 12, 2006 | 11:46 PM
  #9
rmt6668's Avatar
How to remove the centre console to access the Control Unit. The Blower & Regilator is very easy to access beneath the passenger seat dash.
Do I need any special tools to remove the centre console to get to the Control Unit? Are they easy to replace? How much are they & when can I get spare parts in Aust?
Kind Regards,
RMT6668
Old Mar 13, 2006 | 02:06 AM
  #10
could you please tell me the VIN so i can post the diagram/instructions and other details that you need.
