A/C & Heater problems
Old Jun 12, 2006 | 03:48 PM
joerose70's Avatar
Default A/C & Heater problems
Hello. This is my first post; this site is really a great resource!! My '97 E320 has 89,000 miles. Air blows out of vents, but it acts like a fan - no cold air or heated air when temp settings are adjusted. Any thoughts would be greatly appreciated.
Old Jun 12, 2006 | 06:42 PM
vytamenc's Avatar
Default RE: A/C & Heater problems
is the ec light on if it is turn it off. if it wont turn off you have a problem with refigerent pressure.
Old Jun 12, 2006 | 08:16 PM
joerose70's Avatar
Thanks for replying, Vytamenc. No, the ec light (I'm assuming you are refering to the economy light) is not on. If you are refering to the check engine light, it does come on every time I start the car. I am able to turn that off.
Old Jun 13, 2006 | 05:01 AM
cmscott16's Avatar
sounds like a controller problem. ductwork should not be an issue, because even though the heat portion can be sealed off, air usually always runs over the ac portion, even when the ac is not running. have your hvac controller checked out first to make sure it is sending the appropriate signals out to all the components in relationship to in car air temperature.
Old Jun 13, 2006 | 02:06 PM
joerose70's Avatar
Thank you for the info, cmscott16. I'll have the hvac controller checked out.
slkrider123
Apr 9, 2012 04:56 PM
Brian4890
Oct 18, 2007 12:46 PM
dhmaher
Jan 11, 2007 04:41 PM
vinceC250
Nov 20, 2006 09:05 AM
rdolberry
Jul 21, 2005 10:52 PM
