breaking lights not working
Old Jun 14, 2010 | 04:42 AM
KIMIK's Avatar
Default breaking lights not working
hi every one,
please help to solve the problem.
the problem is :
behind breaking lights are not working,
also not working the front right side small (lower) light and corressponding back side lights.
Old Jun 16, 2010 | 04:18 AM
Mcmerc01's Avatar
Check the globes and fuse first. Clean the connection for the rear brake lights, and make sure its properly sealed. Also check for any cuts in the wiring, thats all I can think of as the problem.
Old Jun 16, 2010 | 04:47 PM
chassis221's Avatar
what car and year...but usually the problem is the brake light switch that goes bad...or could just be bad bulbs. if its an E class from 96 up to 2002 could need tail light assemblys
Old Jun 18, 2010 | 11:01 AM
mikieg's Avatar
hey im new to this site, i have a 98 E430 (W210) and with this chassis model the tail light assembly has to be replaced, its actually a factory defect.
Old Oct 3, 2011 | 08:32 PM
jenks2010's Avatar
Where do I find DIY instructions for replacing the assembly? Where do you suggest I order the part from? DO you think I should try replacing the bulb holders and bulbs before tackling the assembly? My brake light on the passenger side don't all work one of the bulbs work in the brakelight and one doesn't. The corresponding front lower light on the right side doesn't work either. So, do you think it s the tailight assembly thats cauing the problem?
patricknif
Mar 4, 2012 06:38 AM
Paul Dalton
Feb 7, 2012 02:37 PM
slick1
Jul 30, 2007 07:05 PM
silverstarcar
Oct 31, 2006 08:48 PM
dave from fiatforum
Jan 24, 2005 09:12 PM
