Brake Bleeding Pattern
I've done a bit of searching and it appears the prescribed bleeding order for a 2002MY W210 (wagon) would be:
LF>RF>LR>RR
Can someone confirm?
I use a MOTIVE pressure bleeder and typically pump it up to 15psi for my other vehicles. What is the recommend pressure for MBz?
Thanks.
LF>RF>LR>RR
Thanks.
Mark, thanks for your note. I had picked up at another site that ABS equipped cars (built after a certain date) are supposed to have the pattern reversed meaning you'd bleed the brake nearest the ABS controller first. I know this to be the case with other marques and has to do with the positioning of the ABS lines.
thanks.
thanks.
PaddyMcWagon
Sep 4, 2011 02:43 AM
