Auxiliary interior heater - How does it work?
Old Oct 19, 2004 | 05:57 AM
tobyd's Avatar
Default Auxiliary interior heater - How does it work?
Hi there,
I have a left hand drive ex-germany 500E that is fitted with the auxiliary heater that has the timer control window just forward of the gear stick. I have no idea how it works or whether it works!
I am trying to find some instructions and also details of where the fuse is so I can get it working now the cold weather is here.
If anyone can tell me how it works and how to trouble shoot it (no life from the display) I would be grateful.
Cheers
Tobyd
Old Oct 19, 2004 | 12:26 PM
tobyd's Avatar
Default RE: Auxiliary interior heater - How does it work?
I foundthis reference to the heater on an obscure web page -
'The auxiliary heater (Zusatzheizung, code 228) is a separate heating
system that works independently of the engine. It consists of a
separate burner unit, an electric water pump, a control unit and it
is connected to the coolant circulation of the engine. It is run on
the fuel of the car (either diesel or petrol, these are different
units for obvious reasons) with a separate fuel line from the tank.
This makes it independent from an electrical outlet and from the
engine. It is started either manually, with a timer (mounted on the
center console or in the glovebox) or via a powerful FM-wireless
remote (the Mercedes units for from about 500 to 1000 metres
depending on local circumstances. The latest versions are available
with mobile phone remote control as well.
Once it is started, a spark plug ignites the burner which heats the
coolant up and the water pump recirculates the water through the
engine. The system heats the coolant up to 80°C and works until that
temperature is held in circulation. Once the temperature of 55°C is
achieved, a separate relay starts the heater blower and this heats up
the interior.
Even at very low temperatures in Alpine or Siberian regions, this
heats up the engine and the interior within 20-30 minutes. Apart from
a warm seat when you step in, the heat melts all snow and ice on the
windows without further ado.
Very comfortable and a must in Southern Germany, Switzerland and
Austria.
Many German Taxis have it as well since it helps them keep warm in
Winter when the wait and have no engine running.'
I still need some info to get mine working as well as instructions so if this rings a bell with anyone I'd love to know.
Toby.
Old Oct 19, 2004 | 06:14 PM
tobyd's Avatar
This is what the heater control looks like in the cabin.
[IMG]local://upfiles/3176/93665CEBE18C4EFEB9C7B588F98D23FE.jpg[/IMG]
Old Oct 24, 2004 | 05:02 AM
jome's Avatar
I suggest you to get a Factory Mercedes Manual.
It has all service and maintenance instructions, step by step.
A great help, hope this will help you.
Here's the link:
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMESE%3AIT
Old Oct 28, 2004 | 09:26 AM
tobyd's Avatar
I have had contact from webasto who supplied the heater to MB and have subsequently obtained some pdf's of the operating instructions as well as a full manual for servicing and troubleshooting. The model no. is bbw46
I hope this will enable me to get my heater working and contact me if you wish me to email the pdf's to you.
Old Oct 28, 2004 | 11:36 PM
MB/TECHMAN's Avatar
WE JUST GOT THE REST BUTTON???
Old Nov 22, 2004 | 02:02 PM
pjcc's Avatar
Hello.
I'm from Portugal and I got a 300 td w210 with that system.
I bought the car few weeks ago, and I don't knhow how that thing works.
Could you send me the pdf's please.
Tank you
My email : pedrocravo2004@yahoo.com
Old Feb 2, 2007 | 10:26 AM
dustindufault's Avatar
Hi there,
I don't have that system in my Mercedes, but I have used similar systems in aircraft, usually small twins. They are known as Janitrol heaters. You might google this and see if it helps you find information. It's a nice system to have, really put out a lot of heat!javascript:void(AddText(''))
-Dustin
Old Dec 11, 2020 | 05:45 AM
  #9
Kingu007's Avatar
Smile
Hello Tobyd,can you mail me the pdf's from webasto ? I dont know how to use it on my W210 of 2001.Thanks
Jopenko1
Dec 10, 2012 03:18 PM
juddycator
Dec 18, 2010 07:45 AM
ml500kid
Dec 3, 2005 04:44 AM
kgreen
Nov 22, 2004 02:02 AM
tobyd
Oct 29, 2004 12:20 AM
