Auxiliary interior heater - How does it work?
Hi there,
I have a left hand drive ex-germany 500E that is fitted with the auxiliary heater that has the timer control window just forward of the gear stick. I have no idea how it works or whether it works! I am trying to find some instructions and also details of where the fuse is so I can get it working now the cold weather is here. If anyone can tell me how it works and how to trouble shoot it (no life from the display) I would be grateful. Cheers Tobyd |
RE: Auxiliary interior heater - How does it work?
I foundthis reference to the heater on an obscure web page -
'The auxiliary heater (Zusatzheizung, code 228) is a separate heating system that works independently of the engine. It consists of a separate burner unit, an electric water pump, a control unit and it is connected to the coolant circulation of the engine. It is run on the fuel of the car (either diesel or petrol, these are different units for obvious reasons) with a separate fuel line from the tank. This makes it independent from an electrical outlet and from the engine. It is started either manually, with a timer (mounted on the center console or in the glovebox) or via a powerful FM-wireless remote (the Mercedes units for from about 500 to 1000 metres depending on local circumstances. The latest versions are available with mobile phone remote control as well. Once it is started, a spark plug ignites the burner which heats the coolant up and the water pump recirculates the water through the engine. The system heats the coolant up to 80°C and works until that temperature is held in circulation. Once the temperature of 55°C is achieved, a separate relay starts the heater blower and this heats up the interior. Even at very low temperatures in Alpine or Siberian regions, this heats up the engine and the interior within 20-30 minutes. Apart from a warm seat when you step in, the heat melts all snow and ice on the windows without further ado. Very comfortable and a must in Southern Germany, Switzerland and Austria. Many German Taxis have it as well since it helps them keep warm in Winter when the wait and have no engine running.' I still need some info to get mine working as well as instructions so if this rings a bell with anyone I'd love to know. Thanks Toby. |
This is what the heater control looks like in the cabin.
[IMG]local://upfiles/3176/93665CEBE18C4EFEB9C7B588F98D23FE.jpg[/IMG] |
I suggest you to get a Factory Mercedes Manual.
It has all service and maintenance instructions, step by step. A great help, hope this will help you. Here's the link: http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMESE%3AIT :D |
I have had contact from webasto who supplied the heater to MB and have subsequently obtained some pdf's of the operating instructions as well as a full manual for servicing and troubleshooting. The model no. is bbw46
I hope this will enable me to get my heater working and contact me if you wish me to email the pdf's to you. Thanks |
WE JUST GOT THE REST BUTTON???
Hello.
I'm from Portugal and I got a 300 td w210 with that system. I bought the car few weeks ago, and I don't knhow how that thing works. Could you send me the pdf's please. Tank you:) My email : pedrocravo2004@yahoo.com |
Hi there,
I don't have that system in my Mercedes, but I have used similar systems in aircraft, usually small twins. They are known as Janitrol heaters. You might google this and see if it helps you find information. It's a nice system to have, really put out a lot of heat!javascript:void(AddText(':)')) -Dustin |
Originally Posted by tobyd
(Post 7974)
