auxilary cooling fan seized-how to replace? 90 300e 2.6
One of my aux fans has seized and won't turn. Has anyone replaced these and can you give me any suggestions on how to R&R the fan? I'm not sure if I need to remove the shroud, engine fan, radiator, etc. or.. can it be replaced right from the front without removing all that stuff? It's the fan on the right(passenger side)
It's a 90 300e 2.6 lter
thanks
thanks
I think they sell each aux. fan separately...(I'm pretty sure this could be done easier, but this is how I removed it) Remove Radiator Fan Shroud Clips and Remove Fan Shroud, remove clips from condensor then pull back then the clips from the aux. fans themselves...
