ASR / Cruise Control - Problem
Old Oct 2, 2014 | 04:36 PM
  #11
Friedolin's Avatar
Default Cruise control
Originally Posted by Friedolin
I have a 1987 300D Turbo with 225,000 miles on it. It is well maintained. The cruise control became erratic last year, on some days it would work perfectly and on others it would not even engage. I finally decided to have it fixed. We changed the cruise control actuater with no change in effect. We disconnected and reconnected the cruise amplifier with no changes taking place either. This leaves the cruise control switch itself, which I have not changed as yet. What are the chances that it is the culprit? On good days it does everything it is supposed to do, but today it would not engage the cruise control once again.
Well, this is 50,000 miles later and I finally figured out that the problem was in the cruise control amplifier. To re-cap, it worked intermittently, hardly ever in the winter time and almost no problem in 90 degree weather after the car was parked out in the sun. Two years ago I had bought another used amplifier that did not work at all. When I told my service guru the other day what happened, he laughed and said that on the replacement you had to disconnect the second ground! And sure enough, he did that and now the cruise control engages every time you try it. The replacement came out of a 1986 300D and sadly, it has other problems, does not like to stay engaged for very long and you have to hook it up again regularly. But at least now I know where the problem was. :-)
Scuddog
Dec 26, 2012 12:17 AM
jaghoub
Jun 5, 2008 02:20 AM
korky
Jul 24, 2007 05:16 PM
bluekangaroo
Apr 29, 2007 11:31 AM
goodluck
Dec 3, 2004 03:39 AM
