97 E420
Old Nov 6, 2006 | 01:50 PM
florin c280's Avatar
Default 97 E420
I have couple of problemms with my 97 420, both related to evap system.
The 2 codes are P0455(evap. system leak -large) and P0446(evap system vent circuit malf)
I already replaced the vent, but nothing happen'.
Before this problem, i had replaced two O2 sensors and both side cats.
Is anybody out there who encounter this problems with evap system?
The car is running ok, but the check engine light comes back every 50k...together with the anouncement on the dash: check electronics
Please help. I have this problem for about 6 mo now....
Old Nov 7, 2006 | 04:05 AM
snanceki's Avatar
Default RE: 97 E420
You need to check the evap lines for damage/splits including all connections.
Best way is to blank off one end of each tube in turn and then see whether line holds pressure or better still vacuum.
....Occurs every 50k..... You've had the car for 6 mo.? You do a lot of miles or was this an error?
Stuart
quibe
Dec 20, 2008 08:57 PM
overrev
Oct 23, 2003 10:24 AM
BMurphy
Oct 10, 2003 06:32 PM
robert
Aug 5, 2003 11:52 AM
edmond03
Jul 24, 2003 05:51 AM
