92 300E 2.6 will not start
Old Dec 30, 2005 | 04:52 PM
colingibb's Avatar
Default 92 300E 2.6 will not start
My 92 300E 2.6 will not start. I hooked up a timing light to check spark and the strobe lights up. I can hear the fuel pump powering up and I also disconnected the main fuel line leading to the throttle body and fuel is running through it OK. Anyone have any idea what the problem is? Could a bad crankshaft position sensor cause this?
Thanks,
Colin
PS Happy New Year everybody!
Old Jan 29, 2006 | 03:30 PM
dave_rose69's Avatar
Default RE: 92 300E 2.6 will not start
If you have spark, the CPS is working. Are the plugs wet with gas after the no start? If they are, your Ign HT spark is breaking down under compression. Go test the spark color. You need a white bluish spark, if its orangy red, go get yourself a new Ign coil. Also change the OVP relay.....
crusier888
Oct 13, 2019 04:46 PM
mercedes_88
Mar 8, 2008 07:02 PM
mercedes_88
Mar 6, 2008 08:09 PM
mercedes_88
Mar 3, 2008 05:52 PM
katinky
Oct 27, 2007 03:40 PM
