91 300E trunk latch problem
Old Feb 2, 2009 | 09:39 AM
marsha's Avatar
Default 91 300E trunk latch problem
Having a problem with the trunk latch.
The small steel "hook" will not move
so the trunk will not stay closed.
Probable cause: Dirt from hauling
plant material may have clogged
the opening. I attempted to
clean out the area but the problem
persists.
Alignment issue ? Broken spring?
New part needed?
Marsha
Old Feb 5, 2009 | 02:06 PM
Smedley's Avatar
Marsha, just pull the bottom trim from the lower deck lip of the trunk. It just snaps in place, then remove the latch and clean it out.
Please note its position, you may have to fool with it to get it tight. Good luck, Smedley
Old Feb 5, 2009 | 06:41 PM
marsha's Avatar
Smedley,
Thank you so much! Most appreciated.
Marsha
rhbelter
Jul 23, 2013 11:34 PM
jtaggart
Apr 28, 2008 07:31 PM
RProsser
Aug 2, 2007 12:02 PM
PrezBenz
Oct 28, 2006 07:02 AM
haoyangqu
Sep 27, 2006 04:55 PM
