88 300E Wiper Motor removal? HELP
O.K all you experts out there. How do I remove the wiper motor or at least the wiper from the motor to access the A/C blower motor.
I am in a bind please advise.
Thank you in advance,
sajohn
sajohn
There is a cover at the base of the wiper arm. Pull up on it at the very bottom. Once this cover is pried up, you will see the set screw for the arm. Once you remove it, you can pull the wiper arm from the motor.
The wiper motor can be removed after the trim at the base of the windshield is carefully pried off, along with the trim pieces surrounding the wiper motor area. There are two (maybe three) nuts that hold the wiper motor in place, plus the wiring harness will need to be unplugged. Pretty straightforward once you get going.
Thanks for the help. I did not mean to insult anyone’s intelligence out there. I had seen it done before and could not remember how to do it. So I knew it would take an expert.
Thanks,
Thanks,
