88 300E relays
88 300E relays
Does anyone have a diagnostic of relays for this vehicle. I need a list of relays in this vehicle, as well as a picture diagram or diagnostic. Can anyone help point me to this or post a link of where this may be available.
Thank You,
Calderon
Thank You,
Calderon
RE: 88 300E relays
My windows all just stopped functioning. The driver window was down part way and it started raining! When I got home. I got some information from this forum to locate the window relay. The window relay is the "F" relay (middle column, all the way to the rear). I read the diagram on the side of the relay and used a jumper wire to jumper the two terminals to give me power to the circuit. Voila, ran up the down window and opened up the relay to see if it was just the contacts. Relay was shot so I couldn't fix it. I guess I'll buy it from the dealer unless anyone knows a better buy.
If you get a map of relays and fuses could you forward it to me also. I have no documentation for these and it would be really helpful. My owners manual says that it is displayed under the fuse box cover, its not.
Richard
Richard
RE: 88 300E relays
you have a monovalve just behind that battery.
the recirculating pump is operated by the pushbutton control module.
[IMG]local://upfiles/1/ABE33D726DC14CEBB77FB15463FE9C2F.jpg[/IMG]
bfigueroa
03-02-2008 08:09 AM
