'87 300E cold start problem
Old Mar 2, 2008 | 08:16 PM
jimkari's Avatar
Default '87 300E cold start problem
I have 1987 300E. The car runs great, never stalls. However if it sits overnight, it's difficult to start. I need to crack it and give it some gas. Once it starts it runs just fine and the idle is very smooth. I checked the over voltage protection relay fuse. That's fine. I also pulled the cold start injector and with it connected, turned the key to see that it was spraying fuel. Although it's hard to tell how much is the right amount, it was spraying a fine mist of fuel. I also tried turning the key on and off a few times before starting to see if the fuel pump was losing its prime. This did not change the condition. After it's warmed up, the car will start immediately. Any advice?
Thanks,
Jim
Old Mar 3, 2008 | 12:20 AM
ohlord's Avatar
Banned
Default RE: '87 300E cold start problem
http://autorepair.about.com/library/...bl647a-lib.htm
controlled by the http://www.autohausaz.com/search/pro...ature%20Switch
14 bucks at autohausaz.com
just like on the newer engines a lazy or faulty coolant temp sensor supplies the wrong value at cold start so the injection system has errant info to process.Easy diy and worth a shot by the symptoms you state.
ohlord
Old Mar 3, 2008 | 08:52 PM
jimkari's Avatar
Thanks for the tips.
Jim
crusier888
Oct 13, 2019 04:46 PM
hmirall1
Jun 11, 2009 03:10 PM
sixfeet750
Dec 18, 2008 05:04 PM
Longhaily
Aug 2, 2008 07:28 PM
redrabbit
Sep 16, 2005 01:53 AM
