300E electrical problems 1991
Old Dec 3, 2009 | 05:46 PM
JRR4948's Avatar
Default 300E electrical problems 1991
Just bought a 1991 300E with 70K. Received the car on a dry day and everything worked. That night it rained and now the Windshield wiper does not function. The power seats only operate when the drivers door is open (Door pin out). last night no power windows. Today dry - power windows work. Still windshield wipers inoperable. Also dash lights are out.
Suggestions?
Thanks..JRR
Old Dec 6, 2009 | 05:59 PM
RPuerini's Avatar
I would first try to find out if thee is a BCM on your car (body control module) If there is, that is the junction where all your electrical components run through. You'll most likely find bad connections where the wires plug in.
Old Nov 1, 2023 | 04:52 PM
Eric Brown's Avatar
Default 91 Mercedes 300E
Replaced body control module and still nothing works seats wipers which come on slightly and move about an inch
Old Nov 1, 2023 | 04:53 PM
Eric Brown's Avatar
Old Nov 17, 2023 | 04:00 PM
tony1963's Avatar
Those older models have a pretty archaic fuse panel. Start by removing all the fuses and cleaning the posts. Then, install new fuses, ideally the copper clad type. I would bet money that your problem will disappear.
Yaoi-Wiccan
Aug 3, 2011 08:25 PM
cliff
Nov 6, 2008 11:29 AM
digi
Aug 27, 2007 12:33 PM
zebinheimer
May 9, 2006 10:01 AM
nach23
Mar 31, 2006 02:29 PM
