300E 1991 vibration at idle only in gear, parked at low rpm
Old Mar 15, 2009 | 08:24 AM
Papatatun's Avatar
Default 300E 1991 vibration at idle only in gear, parked at low rpm
This serious vibration only occurs when in gear and parked, then disappears as soon as the car takes off. The engine does not really shake that much when I look at it under the hood and have someone engaging the transmission in Drive.
Would this problem still be due to engine mounts only (current mounts have about 100K Mi)?
It it was an ignition problem, it should happen all the time, right?
If it is only engine mounts, they are hydraulic and also available as less expensive after market parts: are these OK to use instead of MB parts?
THKS!
RSolares
Feb 9, 2011 08:11 PM
s55_002
Jan 11, 2011 03:49 PM
Papatatun
Apr 25, 2009 12:06 AM
kallejohnson
Aug 15, 2007 03:48 PM
jb91300e
Sep 26, 2006 02:02 PM
