300E 1985 headlight bulb change
After unplugging the cable and pin head, it is really difficult to get the clamp ring out holding the lamp. I tought I had to rotate it, it didn't move. I forced that using a plier but that was not something like corrosion or friction. Something was really holding it. I didn't go further since I didn't wanna break it. Does anybody have an idea to take it off ? Thanks.
I have a 300D from that same year. If it is the same round headlight that I have it takes a little jockeying to get out. Basically you just have to kind of play with it a while and use a little force but not enough to do any damage. That should get it out. You could always put a little WD 40 on the ring to make the glass slide through easier. Hope this helps if not let me know.
Thanks, WD40 really worked. What i did was very funny: I sprayed the WD and waited for a while. Then, I started tapping all around the ring using a screwdriver and a hammer. Just a little by little all around it made the WD absorbed fully. Kinda vibration thing helped too, I didn't need to use the plier again it just released itself as soon as i grabbed and started rotating it. Well, 20 years of bonding made me really think that it couldn't be opened by rotating that was so concrete. Thanks again.
Dwd123
Feb 24, 2006 10:54 PM
