300CE A/C TROUBLES
300CE A/C TROUBLES
MY CE HAS A/C PROBLEMS..I HAVE REPLACED THE HOSES, DRIER AND EXPANSION
VALVE...IT WILL HOLD A STEADY -25PSI ON PURGE. THE PROBLEM IS I CANT
GET IT TO TAKE A CHARGE. THE CLUTCH WONT ENGAGE AND TESTING AT THE 3
LEAD CONNECTOR SHOWS NO POWER. I CHECKED FUSE #7, THE LARGE FUSE IN
FRONT OF THE FUSE BOX, AND THE KLIMA RELAY. EVERYTHING LOOKS GOOD. ANY
IDEAS?? I ALSO TRIED APPLYING POWER TO THE BL/GREEN WIRE AT THE CLUTCH
STILL NO ENGAGEMENT, DOES IT NEED TO HAVE AN INDEPENDENT GROUND?.
