2003 E500 - Battery Malfunction, Electrical Consumers Turned Off
Old Mar 30, 2008 | 12:23 AM
  #11
saleen1276's Avatar
Default RE: 2003 E500 - Battery Malfunction, Electrical Consumers Turned Off
also have a problem with BCM (battery control module)--they have to be "flashed" with new software or possibly replaced--and also the battery under the hood is only used for starting the vehicle---bcm is located in the trunk/cargo area next to the battery ****
Old Apr 4, 2008 | 09:19 AM
  #12
vettdvr's Avatar
Perhaps I am mistaken, but I thought the E500 main bat. had a low voltage tap on it and the most replacment batteries don't have this tap. What is the purpose of the tap? "lower voltage"? How can you buy a battery from Cosco and get the correct battery with this extra tap. Our E500 was bought new and this is no add on, but came from the factory this way. Thanks?
Old May 21, 2009 | 08:58 PM
  #13
herxing's Avatar
any body can explain what is back up battery in e500 , 2003
i change a new battery, but the battery red sign still on, the MB service said
i have to change the back up battery, it cost $500..00
i am not willing to change it, but the gentleman said i have to change it
i fell be cheated
anybody can explain it for me ? thanks
Old May 21, 2009 | 09:05 PM
  #14
chassis221's Avatar
500! oh my god. i work at dealership and that sounds high to me. i think the battery might be 200...just a guess but you can install it yourself. under the hood , passenger side, under the windshield, under the black cabin filter housing.
Old May 21, 2009 | 09:15 PM
  #15
herxing's Avatar
Unhappy
i don't think i can do it.
i am so mad with MB !! the service rep not the one i always call.
they told me they spent 3 hours to find the problem , u believe it ?
suppose they can use computer to check it right?
Old May 21, 2009 | 10:16 PM
  #16
chassis221's Avatar
well computer doesnt really point you to the problem, it gives a general idea. depends though. 3 hours to find the problem is what the tech said. if you tell them to check out the problem then they usually charge an hour diagnosis but more than that they should call and tell you they need more diag time. but just to tell them to put in a battery without diag shouldnt be 500. there are many times that i work on a benz and the computer wont tell you anything at all...50 percent of the time.
Old May 25, 2009 | 09:24 PM
  #17
aquaseve8's Avatar
I purchased a 1998 e320 with 120k on the clock. If the battery is going bad, will it give any warning? Is it necesarry to plug in a back up battery (at the cigarette lighter) before disconecting the main battery? (in the event of putting a new one)
Old Jun 23, 2011 | 03:38 PM
  #18
nyqster's Avatar
I recently replaced my battery, alternator & the small battery under the hood & i still have electrical consumers switched turned off display message pop up along with Brake visit workshop & car with an arrow in it facing up also saying visit workshop.
Any answers?
Donovano
Mar 11, 2010 09:03 PM
cspears1
Sep 23, 2007 02:13 PM
Jsun
Aug 16, 2007 12:05 AM
zjb0387
Aug 7, 2007 10:19 AM
krl
Apr 24, 2007 04:50 PM
