2003 E320 - Steering Wheel Vibrates at 50mph and 80mph
Old Jan 30, 2008 | 07:39 AM
mor911's Avatar
Default 2003 E320 - Steering Wheel Vibrates at 50mph and 80mph
I was thinking I just need to get the tires balanced and a front and rear alignment... Is this the right course of action? Do you guy know something I don't?
Also, I see some "Mercedes Repair Shops" around town... Obviously not dealerships but they say they work on Mercedes'. Should I get work done there? Or not chance it and go direct to the dealer (and pay top dollar)?
Old Jan 30, 2008 | 11:22 AM
snanceki's Avatar
Default RE: 2003 E320 - Steering Wheel Vibrates at 50mph and 80mph
IMHO have someone who is familiar with the sensitivity of an MB do the work. A dealer would be a good call but I guess there are others with the correct equipment and expertise. Many tyre shops should be avoided since they don't follow the MB procedure or use 4 wheel equipment.
Unless the vehicle has already been "tracked" by a tyre shop somewhere I would leave Track well alone unless your tyres are showing specific tracking damage.
NB MB's wear the inside/outside edges of the tyres badly even when all is set up OK. Just look at the angle of the front wheel after moving backwards on full lock!!
Wheels should be checked for roundness and then balanced OFF CAR.
If you continue to have problems then things get a load more complicated and you may have tyres which are out of spec.
Stuart
Old Jan 30, 2008 | 04:54 PM
BluePearlDog's Avatar
Same problem, replaced drivers side tie rod end and 4 wheelalignment, vibration gone, $150 at indy shop.[/align]
Old Jan 31, 2008 | 07:22 AM
mor911's Avatar
Awesome! I'm gonna get it done fist thing tomorrow.
Old Jan 31, 2008 | 12:48 PM
ORIGINAL: mor911
Make sure that is the problem. I could shake the wheel by pulling back and forth at the top of the tire.
Old Feb 2, 2008 | 09:51 AM
mor911's Avatar
Just to keep you guys updated, my front right tire was warped (wasn't perfectly round). No matter what he did, he couldn't balance it. Maybe i nailed a pothole or something. Went to a tire shop, bought two new front tires and balanced them. Problem solved
Old Feb 2, 2008 | 05:47 PM
Glad your problems solved.
luvmysl
Jan 30, 2010 03:43 PM
AMGMercedes
Apr 2, 2007 10:49 PM
osharif
Mar 10, 2006 09:29 PM
passatvr6
May 25, 2005 12:17 PM
rverma
Feb 8, 2004 12:02 AM
