2000 W210 4Matic broken motor mount perch
Old Dec 20, 2009 | 08:26 PM
cgower's Avatar
Default 2000 W210 4Matic broken motor mount perch
Has anyone run into the situation where you go to replace the motor mount and find that the perch/strut is broken instead? Since I have the 4Matic, I am really not looking forward to tackling this job, but may have to. The aluminum perch/strut was stuck to the top of the motor mount and found that the mount really didn't have to be replaced, same size as the new one. The front axle was rubbing on the lower control arm I believe or the body where it passes through on it's way to the steering knuckle and made a grove in it. This is really weird. Anyone tackle this job?? Anyone have any information or hint, tips or anything? I would really appreciate it. Do I need to pull the engine to do this? What do you call this piece? Please advise.
Old Dec 20, 2009 | 08:28 PM
chassis221's Avatar
i did one on the left side of a 4 matic e class 2001 wagon. very messy and tight. youll probably need a lift to do the job.
Old Dec 20, 2009 | 09:09 PM
cgower's Avatar
Mine is on the left as well. What is the part called?? How much for the part? I don't expect that you would remember every job, but maybe a ballpark? It looks real messy. Any hints/tips? They would be appreciated.
PelicanParts.com
Jul 22, 2013 12:15 PM
brudd
Mar 3, 2007 07:44 AM
gasdude
Jan 31, 2007 06:01 PM
brink
May 3, 2006 05:27 AM
Xacting
Apr 5, 2005 12:52 AM
