2000 e320 limp mode issue p0715
Old Mar 29, 2019 | 05:54 AM
justinbenz320's Avatar
Default 2000 e320 limp mode issue p0715
hello everyone. i have recently purchased a 2000 e320 with no problems after a month. then backing out of a parking spot i realisei was just spinning rpms, no accell. i turned it off turned back on and left gas station. went a tenth of a mile when the car staarts jerking at about 40 mph, then lost all gears .limp mode home
i have a innova 3160 scanner i iulled p0700 p0715, replaced conducter plate with new one from oreilys and new harness connector was super careful not to get any debri inside.out of habit i unhooked the battery before. now i cant clear the 715 keeps saying fix asisst on my scanner. initially when i i started up after repair warnings of abs and esp flashed but was able to clear those,. now stuck 1st gear limp mode 30 mph tops at 4,000 rpms. any help or tips would be much appreciated .
Old Mar 31, 2019 | 12:41 AM
Default P0715 help
Is rhere anything I couod suspect as the problem that wouod not throw a code?
Old Apr 1, 2019 | 03:54 PM
PelicanParts.com's Avatar
Hello and welcome to the forum! I believe in order to clear the code, you'll likely need a dedicated Mercedes scan tool. A lot of the generic obd2 tools will not be able to clear the code. Please let us know if you have any other questions. Thanks!
estatepro
Jan 5, 2009 04:49 PM
SPVFD47
Jul 5, 2008 10:29 PM
sixsense
Jun 5, 2006 09:24 PM
aarlucas
Mar 10, 2006 09:54 PM
addys
Jun 23, 2005 12:09 AM
