1999 E320 167500 kms - Error codes - need advise
Old May 29, 2010 | 06:39 AM
vignesh's Avatar
Default 1999 E320 167500 kms - Error codes - need advise
PO141, PO156, PO132 &PO161 for 1999 V6 E320 with 167500 KM, but car driving smooth. fuel economy is 10 liters per 100kms.
Advise would be greatly appreciated...
Thanks.
Old Sep 3, 2012 | 07:00 PM
Friedolin's Avatar
I have 1998 E320 with the same problem. Had it for years. You have to understand that this is an oxygen sensor preheat fault indication. It is valid only during engine warm-up. If the check engine light comes while driving, it's a computer glitch you can ignore. If it does not come again for 200 miles, the computer will clear itself and the check engine light will go out. You can do the same with an engine code reader and clear the fault with it. I have been doing this and the check engine light some times will not come on again for a montyh or two.
miebi
Dec 12, 2011 02:46 AM
suomaf
Jul 15, 2010 09:39 PM
SeiyaMiami
Mar 16, 2009 11:13 PM
Sarge
Aug 3, 2004 05:13 PM
JSquared
May 16, 2004 09:31 PM
