1997 e230 gearbox problem
Old May 14, 2014 | 06:37 AM
amr_shahzad's Avatar
Default 1997 e230 gearbox problem
I have purchased 1997 E230 recently, the problem I am having is that when I reduce speed and the gear gets down a jerk is felt, there is no problem when the gear is changing from lower to higher but when it gets changed from higher to lower the jerk in gear box is felt.
I have checked the transmission oil and it is ok, what could be the problem? please help.
Old May 14, 2014 | 07:39 PM
chassis221's Avatar
Originally Posted by amr_shahzad
probably an issue with the valve body, or the conductor plate. could also be a worn out driveshaft coupler/flex disk. maybe motor mounts or a transmission mount.
Old May 15, 2014 | 06:01 AM
hi chassis221,
someone advised me to first have computer test of the gearbox, so after that I will let you know the results for further advise.
simonttl
Nov 25, 2014 02:39 AM
kmac
Feb 19, 2011 05:18 AM
skar23
Oct 1, 2010 01:54 PM
NIPPY
Jul 19, 2010 08:31 AM
dendua
Dec 5, 2007 07:44 AM
