1991 300E Wont start when cold/must hold down gas petal.help!
Old Nov 20, 2008 | 08:00 PM
MARIODRIVE's Avatar
Default 1991 300E Wont start when cold/must hold down gas petal.help!
this thing is driving me nuts i need this car darn thing just wont hold at start up i need to keep my foot on the gas petal to get it warmed up.. even then i must keep on giving her gas even when i stop in drive.I have checked for vac leaks ,checked the linkage at air intake..any clues would be very much appreciated..lost in N.Y.
Old Nov 20, 2008 | 08:14 PM
cliff's Avatar
Default RE: 1991 300E Wont start when cold/must hold down gas petal.help!
what I would do, for whatever...is replace the coolant temp sensor and any associated coolant loss. As a start that is...should only be around $40 parts..good luck
Old Nov 20, 2008 | 08:29 PM
MARIODRIVE's Avatar
I MENT WHEN THE CAR IS AT IDLE..
Old Nov 21, 2008 | 05:20 PM
Smedley's Avatar
I had a little of the same problem, I trust you have cooper core spark plugs???, if the cold start valve does not do the trick, check your dist. cap for cracks or carbon. I cleaned mine and trouble went away. Also coil, I believe you have a spark problem that my require dist. cap, plugs, wiring and coil to put a big grin on your face. Smedley
crusier888
Oct 13, 2019 04:46 PM
damiano777
Apr 25, 2011 08:02 PM
MARIODRIVE
Nov 23, 2008 05:39 PM
eastwest
Nov 23, 2005 07:23 PM
sdanville
Sep 16, 2004 09:53 AM
