1990 300e Fuse Locations?
Old 02-16-2007 | 06:04 PM
tygger's Avatar
Default 1990 300e Fuse Locations?
I lost my users manual and need to check some fuses. The only fuse location I found was near the driver's side firewall in the engine compartment. Does anyone know if there are any other locations to check???
Old 02-17-2007 | 02:05 PM
boycbronco's Avatar
Default RE: 1990 300e Fuse Locations?
That's the only location I am aware of.
Old 03-01-2007 | 01:16 AM
brian576's Avatar
yup, that's the only location, if you need a fuse diagram though I can scan mine and get it to you this weekend
Old 03-01-2007 | 01:41 AM
tygger's Avatar
Thanks, but I think I got it figured out.
Old 03-04-2007 | 06:16 PM
stahlkrieger's Avatar
Behind the battery covered by a plastic cover is a 10 amp flat fuse on the OVP relay (over voltage protection). Also, closer to the firewall, (behind the fuse box you found) is a cover held by screws...if memory serves there are a couple fuses there too.
Michael
Old 06-08-2007 | 09:47 PM
forgetit60's Avatar
Default 400e fuel relay location
Old 07-17-2007 | 06:54 PM
hittcontact's Avatar
Hi all
I'm now to MB cars and have E300 diesel.The environment control suddenly stopped working.When I try to turn it on, there is no noise at all. Even the fan does not turn on.
Any ideas....please!!!!!!
Old 09-27-2012 | 12:10 PM
Robert Driggers's Avatar
where is tps fuse located
S430
09-23-2008 08:09 AM
TimCollins
12-13-2007 06:39 PM
antfow
06-03-2007 12:50 PM
desperado
07-25-2006 10:16 PM
stahlkrieger
07-07-2006 11:28 PM
