1988 300TE idle problem
Old Nov 26, 2006 | 09:59 PM
jrschroud's Avatar
Default 1988 300TE idle problem
Engine does not want to idle when first started cold or after sitting for more than 15 min. Takes serveral to many start attempts to get the engine to idle roughly. Once engine warms up it idles OK. Not the cold start valve, idle control valve, engine computer, or air mass sensor. Cold start valve and idle control valve are new. Tried a spare engine computer that I have. Idle valve sensor on air mass sensor tests within specified limits (> 1.0 ohms).
Old Nov 27, 2006 | 02:55 PM
leon s.'s Avatar
Default RE: 1988 300TE idle problem
Did you try:
- to adjust the iddle with the screw in middle of the air filter box (use a long allen key)
- adjust the tension of gas pedal cable?
Old Dec 3, 2006 | 04:20 AM
vytamenc's Avatar
could be alot of things adjust lambda first. you must have a meter to do that or you will just screw things up more.
bacullen
Aug 17, 2005 04:30 PM
Mwagon
Jun 3, 2004 03:15 AM
BlueBelly
Sep 19, 2003 02:32 AM
duchida1
Jul 24, 2003 04:02 AM
duchida1
Jul 24, 2003 04:00 AM
