1988 300E idle
Old Sep 23, 2010 | 06:23 PM
Baseball998's Avatar
Default 1988 300E idle
I have a 1988 300E, with 100K miles. The car starts fine and is fine at highway speeds but has a very rough idle, the RPMs range from about 5-800, and the needle fluxuates slightly. The vehicle shakes as well at idle. When I step on the gas pedal, there is a lack of reponsiveness. Usually, I will step on the gas and it acts like it will stall and then the engine catches up to the gas pedal and accelerates as it normally would. It stalled once at a stop sign. Any ideas on what may be wrong? Thank you.
Old Sep 30, 2010 | 08:11 PM
rickyb's Avatar
thers a relay behind the battery with a fuse on top im told its the ovp relay my 1990 300e had the same problem the garage changed it and it stoped stalling there between 55-75 dollars depends were you buy it its about two or three inches tall .
Baseball998
Oct 4, 2010 12:33 PM
BobbyK
Dec 18, 2006 02:38 AM
jrschroud
Dec 3, 2006 04:20 AM
BobbyK
Apr 14, 2006 05:41 PM
bacullen
Aug 17, 2005 04:30 PM
