1987 300TD Trunk lights stuck on
Old Dec 5, 2007 | 09:43 PM
TheDeepFryedBoot's Avatar
Default 1987 300TD Trunk lights stuck on
I am not sure which class this is so I am going to post this here.
I have a 1987 300TD wagon which is having a rather strange problem. Today my brother locked the car and the car alarm went off after about a minute. He locked the car again and everything seemed ok to him. I came to the car and all of the courtsey lighting in the trunk and back seat is on and wont turn off. I pulled fuse C and they went off. Because I need that fuse for other things such as locks I put it back it...the lights are now off and they come on just fine when I open the doors and turn off when the doors close. OK, it seemed like I fixed it, I came back outside about an hour later and all of the lights are back on again. Since the doors work after pulling the fule for 10 sec and putting it back in, its oviously not the switches for the lights. What is going on and how do I fix this?
Old Dec 6, 2007 | 09:48 AM
syedabdulshahid's Avatar
Default RE: 1987 300TD Trunk lights stuck on
It can be fixed:
You need to disconnect the battery for 4 hours to reset things.But, before you do that you
should know your radio reset code.You caneither find it in the owners manual or contact the
MB dealer who can find it for you by putting in your VIN ( Vehicle Identifcation Number)
Let us know of the results
Regards
Syed
Old Dec 6, 2007 | 11:25 AM
OK, luckly I have a new radio that does not have the security codes enabled. What exactly would disconnecting the battery do? Also, would this have anything to do with the fact that I changed the battery 2 weeks ago because it was going bad? I had to jumpstart the car several times.
Old Dec 6, 2007 | 08:34 PM
Well, I tried it for 4 hours but its still broken. I am going to leave it unplugged overnight to see if there are any improvements.
Old Dec 7, 2007 | 06:11 PM
No luck. The lights still wont turn off. Does anyone know which computer handhes those lights? I want to go check the connections and make sure it has not gotten water in it.
Old Dec 9, 2007 | 07:32 PM
Well, we fixed it. It seemed that the insulation on one of the wires had pulled back a little and had grounded the lighting system therefore making it stay on. Luckly I had the wiring diagrams and was able to trace the wires down.
starchild
Jan 27, 2026 06:10 AM
foto1
Dec 15, 2014 10:58 AM
wessie
Apr 4, 2013 10:39 AM
rover1
Jan 31, 2010 08:21 AM
slick1
Jul 30, 2007 07:05 PM
