190e help
I need to find out where vacuum line for the fuel pressure regulator goes on a 1993 2.3. Also need to know where vacuum line goes that is on the big rubber pipe that goes into the aircleaner,as well as the valve cover and somewhere else.
Also need to know where the heavy red wire with green stripe that is near the fuel pressure regulator goes, it has a female connector.Thanks
<LABEL id=HbSession SessionId="2191234374">The "vacuum line" from the fuel pressure regulator is connected to the breather hose coming from the airfilter housing.</LABEL></P>
<LABEL SessionId="2191234374">Yours probably broke in 2, so you have one half on both ends.<IMG src=smileys/smiley1.gif border="0"></LABEL></P>
<LABEL SessionId="2191234374">This "vacuum line" is actually a vent hose for the fuel pressure regulator.If the diaphragm in the regulator siezes, fuel will vent out from this hose to the breather hose (very little from experience).</LABEL></P>
<LABEL SessionId="2191234374">FYI, breather hose goes from airfilter housing to valve cover to idle valve.</LABEL></P>
<LABEL SessionId="2191234374">Cheers.</LABEL></P>
harryi
05-02-2010 02:36 AM
elara61
06-16-2009 01:58 PM
