cls door handle
the door panel does not need to come off. its usually on the side of the door, youll need a long thin torx to get in there, but youll have to remove the key hole part first with the torx. loosen the torx, it doesnt need to removed totally, uncrew it until you feel the tumbler/infrared reciever piece loosen after youve loosened the screw enough then youll be able to pull out the reciever/keyhole part,,then the door handle part will slide sideways and remove. be craeful not to drop the screw down in the door itself so i recommend leaving the torx screwdriver in the door while doing the work.
landsteam
Nov 5, 2011 09:26 AM
mbz_tech
Feb 1, 2011 11:47 AM
