No heat - EC light on
Well, I just completed fising one problem and now it appears I have another. It is below zero this week, and the heat in my CLK 320 is barely warm. I noticed in an earlier post that the EC light lit indicates a problem, but looks more like AC related. Could this EC light also be linked to a heater issue?
EC light means "economy"....It turns off the A/C compressor...... If you cant turn off the light, then that means the system prabably isnt charged properly.....It turns off the compressor to keep it from being damaged......It also might be a bad evap temp sensor....If the sensor is faulty, it usually thinks the evap is too hot.....Which means it will keep it from getting hotter by turning off heat...
Kikoap
Jul 30, 2012 02:50 PM
Kikoap
Mar 27, 2012 10:37 PM
