help the EC Light is on!!!
Does anyone know how to get this to turn off? The dealer thinks I have to replace the condenser, but I am not convinced.....
When I first turn the car onthe ECis on. I turn the key off and then on and I am able to turn the EC off. The AC works perfectly when the EC light is off.
There is also a clicking in the engine when the light is on, but disappears when I turn the EC off. Any help would be appreciated.
Thanks.
The EC light stands for "Economy". When the light is on that means the compressor is off. If you cant get the light to turn off that means the system has low freeon. The a/c compressor will not run if the system is low on pressure to keep it from damaging. How long has it been since you last recharged it?? Your system might have a leak in it.
I have the same indications, where the EC light comes on randomly, and may be extinguished only if you cycle the ignition (off and back on).Afterdoing so,theAC blows cold.
I did just have the freon re-charged, and the suquently the o-rings changed at the condenser, and then re-charged, again.
Is it possible there is a code stuck in the OBC?
mine is a '99 clk-320
thechef
Feb 4, 2014 06:51 PM
Kikoap
Jul 30, 2012 02:50 PM
Kikoap
Mar 27, 2012 10:37 PM
95ee320
Nov 27, 2006 05:14 AM
Matz445
Oct 12, 2006 05:39 PM
