CLK350, 2008: Crank, But Does Not Start, HELP!!!
Old Mar 28, 2023 | 07:30 AM
mrcarlos's Avatar
Default CLK350, 2008: Crank, But Does Not Start, HELP!!!
Hi Guys,
Here’s the issue that I'm dealing with, I will appreciate any help if you have experience with any of those symptoms:
My Car: CLK350, Year 2008, 3.5 V6
Car was working just fine, until this past Saturday, I turned the car on, a/c, everything, was inside making a couple of phone calls, put the car into reverse and took in out of my garage, a few meters after like 5-10 meters the car die on me and from that moment it does crank, but not start.
Battery like 1 year old, tested good voltage, starter is good, car keep cranking fine, all fuse- relays seems to be good/ in special I checked the one related to fuel pump, all sees to be good, I tested with multimeter.
*Replace all cps and crankshaft sensors, nothing yet.
*Fuel pump is getting power throw one of the wires, but not sure if get activated by a signal or something since it does not seem to be working, also tested the fuel flow to the inyectores and there’s none.
Not sure if it may be the actual pump of some other sensor that it does not let it run properly, as stated before, car is my daily driver was working just fine until suddenly this happened.
I use throttle cleaner, the car started for a few seconds, like 1-2 secs, but did not stayed on, just die again.
No code on the ECU.
I already tried a couple of things I read here on the forum, but nothing seems to work,
any suggestions, please help?, not sure what else can I check on?, somebody with better experience having the same issue?, at this point I don't know what to do...
BuzzRam
Mar 15, 2022 11:07 PM
drew34drewbie@yahoo.com
Jun 17, 2009 01:38 AM
OrangeCountyGirly
Nov 21, 2007 02:36 AM
