clk230 missfire
start up from cold try and pull away and engine missfires traced problem to number 2 injector when missfire occurs it will miss as long as the engine is running,switch off and switch on again and the missfire clears and it will run ok all day,checked injector wireing and it has a 12v feed,it seems to be the signal wire that is looseing its signal i suspect the e.c.u,anyone had this problem
thanks
cyril
thanks
cyril
