clk windscreen problem
I have A windscreen for my 2003 clk and it appears the spring in the latch came off. has anyone had this problem if so how did you fix it? it is very difficult to see in such a small area.
thanks
thanks
It's a tricky job and having a pair of locking needle nose pliars is almost a necessity - actually make it easy on yourself - go to Radio Shack and buy a couple of pairs of locking 'hemostats/forceps". You have to thread the spring backaround theretaining post, then so the problem doesn't occur again, use a dollop of some type of adhesive (I used black silicone seal). You need to keep the 'arm' extended until the adhesive dries or you'll likely have to start from square one again, but this time pick out the silicone first... Just remember, PATIENCE, PATIENCE.
2000, 2003, 2006, benz, clk, cpk, installation, mercedes, radio, radioshack, release, repair, shack, windscreen, windscren
