Change bulbs on fog lights
Old Mar 16, 2010 | 10:13 AM
Norman Bank's Avatar
Default Change bulbs on fog lights
I have a CLK 320 2005 and want to change the bulb. Is it a simple task or do I have to bring it to a Mercedes dealer?
NHBANK
Old Mar 16, 2010 | 06:32 PM
chassis221's Avatar
youll have to get on your back and remove the panel under the fog light assembly 3 10mm in the wheel well and 4 or 5 pushpins at the bottom and also remove 2 of the 8mm screws from the other belly pan because it sort of covers part of the fog light belly pan then youll have access to it. not sure if theres a cover on the 2005s fog light. easy to do.
Old Apr 8, 2010 | 06:59 PM
angggela's Avatar
you don't need to get on your back and do it. i change all my bulbs from fog lights to the lic plate holder lights above it. all you have to do is pop the hood open, and change the bulbs. i did that and opened the "lid" that is keeping everything in place. i think its just easier than getting on your back
Old Apr 8, 2010 | 08:22 PM
chassis221's Avatar
the fog lights are at the bottom of the bumper and you access them under the car. or threw the wheel well liner. you cant reach them from under the hood? if you can change a fog light bulb at the bottom of the bumper from opening the hood and reaching down you must have some very unique arms.
vmb2000_uk
Nov 5, 2010 10:11 AM
ARMENDS500
Oct 9, 2007 07:49 PM
slick1
Jul 30, 2007 07:05 PM
MetzLyov
Sep 4, 2006 12:29 AM
clkgeorge
Jun 24, 2005 07:40 PM
